Odd bug
I think this might be a memory error or something, but I can't figure out how to fix it.
The project I'm working on is persistance of vision on a bicycle wheel.
At the beginning of the program, I define some text phrases, like so:
and everything is fine, until I add the 5th phrase. At that point, everything keeps working, except the 'space' character in every phrase has 3 dots in it.
I guess I have to go deeper into how the program works...
First, I made an alphabet/font for the LEDs (dots are off, ones are on).
The first data point is how many columns are in the letter, (mostly 5, but some letter like 'W' or 'M' are wider). The following N bytes define how the letter looks.
Then there's the code to display one letter: It just cycles through the data for one letter, and outputs that to the LEDs.
Then the code to display an entire phrase:
Then there's some code to cycle through all the phrases. Like I said, with 4 phrases, everything is fine. With 5 or more phrases, all the letters display ok EXCEPT for the 'space' character. It ends up looking like this:
I've tried adding some dummy data, in case their was a bad memory location. And I just can't see anything in the code that would change the output based on the number of phrases that are in memory.
Any ideas?
Post Edited (asynchronous13) : 7/28/2006 2:04:38 AM GMT
text0 DATA "CRITICALMASS.ORG ",255
text1 DATA "FASTER MUSTACHE ",255
text2 DATA "SOPO BIKES ",255
' .111. ' 1111. ' .111. ' 111.. ' 11111
' 1...1 ' .1..1 ' 1...1 ' 1..1. ' 1....
' 1...1 ' .1..1 ' 1.... ' 1...1 ' 1....
' 11111 ' .111. ' 1.... ' 1...1 ' 1111.
' 1...1 ' 1111. ' .111. ' 111.. ' 11111
letterA DATA 5,$3F,$48,$48,$48,$3F
letterB DATA 5,$41,$7F,$49,$49,$36
letterC DATA 5,$3E,$41,$41,$41,$22
letterD DATA 5,$7F,$41,$41,$22,$1C
letterE DATA 5,$7F,$49,$49,$49,$41
' --------- Display One Letter Routine
oneLetter:
READ letter, numColumns
FOR column = (letter+1) TO (letter+numColumns)
READ column, LEDvalue
OUTL = LEDvalue
NEXT
' put a little space between letters
OUTL = 0
RETURN
scanPhrase:
READ phrase, nextLetter
IF nextLetter = 255 THEN phraseDone
LOOKDOWN nextLetter, [noparse][[/noparse]"ABCDEFGHIJKLMNOPQRSTUVWXYZ ."], nextLetter
LOOKUP nextLetter, [noparse][[/noparse]letterA,letterB,letterC, ... ,letterZ,letterSpace,letterDot], letter
GOSUB oneLetter
phrase = phrase + 1
GOTO scanPhrase
' ..1..
' ..1..
' ..1..
Any ideas?
Ryan
Ryan Clarke
RClarke@Parallax.com
Easiest way to do that is create a 'Quick Reply', submit it, then Edit (with the little 'pencil' icon) the reply, click the Attachment, and enter the path to your file.
