Generic Robotic base
Thought I would share this tutorial project with you guys, It is a generic robotic base platform that was started one weekend and finished four weekends later. It will have many more add ons when time permits. I will incorporate ping ultrasonic, PIR, digital voice recorder and camera with pan/tilt. Here is the link to the tutorial. The project is using The Parallax Profesional Dev board and HB25 Motor controllers + Blue Bell Design subsumtion board.
http://pruim037.proboards107.com/index.cgi?board=nonww&action=display&thread=1150615368
And a video:
Code can be found here: http://forums.parallax.com/forums/default.aspx?f=10&m=130171
If anyone can help me out with inserting the right code for the code above, it would be appreciated. This extra code would be for the PIR, ROAMING PING, + PAN/TILT SERVOS, Also for four GD2P12 analogue distance sensors, as I am not sure where to insert this to opperate the two motors so that they do not collide with walls ect.
Thanks in anticipation.
Hope you like it.
Never give up when things go wrong.
Post Edited (StampNut2) : 7/12/2006 6:34:08 AM GMT
And a video:
Hope you like it.
go to drrobot.com to find some good human detection modules that will work
I looked over your platform project and can see you have given it a lot
of thought and effort.If you can manage to get this far,it should be no problem to learn the code as needed.
The camera pan and tilt could be achieved with the use of servos.A small camera should direct mount to the servo horn.The code can be found in "What's a Microcontroller",
chapter 4.Very simple to implement.And the digital voice recorder might be switched on and off with a relay,as directed by your Stamp.
Good luck,nice work so far.
Thanks, Parallax!
·A.C. fishing: for your comments on the PIR· and will have a look at the site you suggested. Sorry for the late reply Ihave been away for 4 days.
There are only two things in life: fun & death. Let me know when I'm having fun.
http://www.bluebelldesign.com/CoP_Bd_kit.htm Hope this helps to understand this board, It's very easy to use. It already has one irpd and bump sensors and can accomadate four A/D inputs such as the GD2P12 Distance sensors and eight servo inputs.
Thanks so much for the info on the Blue Bell board. You are a true gentleman. It sounds neat and I'm going to look into it.
All the best to you.
