Touchscreen menu system code help needed
Hello all,
i come with an interesting bit of code. It's for a mfancy menu system i'm developing. It shouldbe fairly basic in opperation, and i've been pummeling my head into wall trying any way i can think of to get this now numeric (1,2,3,4) multi-level menu system to work. This is what i have so far, if your so enclined to assist I attached the scource.
For some reason i cannot figure out, the primary menu "buttons" appear, but when you make selection 1 off the primary menu, the selected submenu title bar and background display correctly, but all but the fourth menu "button" doesn't display. The menu system is setup so that pressing "1" will select the upper left button, pressing "2" will select the upper right "button",pressing "3" will select the lower left button, and pressing"4" will select the lower right button. I know the menu structure isn't fully complete, i'm wondering why the buttons on the submenu won't print to the debug correctly. Thanx in advance for any help pointing out my idiocracy,
Definetly a E3 (Electronics Engineer Extrodinare!)
"I laugh in the face of imposible,... not because i know it all, ... but because I don't know well enough!"
' {$STAMP BS2}
' {$PBASIC 2.5}
' {$PORT COM1}
x VAR Byte
y VAR Byte
xloc VAR Byte
yloc VAR Byte
menu VAR Nib
sub_menu VAR Byte
title VAR Byte
temp VAR Word
cnt VAR Word
char VAR Byte
x_mem VAR Word
xa_mem VAR Word
xb_mem VAR Word
xc_mem VAR Word
xd_mem VAR Word
x =0
y =0
xloc =0
yloc =0
menu =0
sub_menu=0
title =0
temp =0
cnt =0
char =0
x_mem =0
xa_mem =0
xb_mem =0
xc_mem =0
xd_mem =0
DATA " LASC ","X-Over ","PWR OPT"," N/A ",
" Input ","Output ","Frq Tap"," Trigg ",
" Low "," Mid "," High "," Full ",
" Bank1 "," Bank2 "," Bank3 "," Bank4 ",
" Type "," 1-way "," 2-way "," 3-way ",
"Ctr Frq","Quality"," Level "," ",
" Alarm "," LVPD ","AutoI/O"," ",
"Main Menu",0,"L.A.S.C. Menu",0,"X-over Menu",0,"Power Options",0,'----------------------title bars
CRSRXY,0,4,CLRDN, '--------------------------------------------------------------------------fine adjust background
" ____ 0 ____ ",CR,
" - ___________ +",0,
CLS,CRSRXY,7,1,"[noparse][[/noparse]]",CRSRXY,7,2,"[noparse][[/noparse]]",CRSRXY,0,3,"----------------",CRSRXY,7,4,"[noparse][[/noparse]]",CRSRXY,7,5,"[noparse][[/noparse]]"
wait_for_invoke:
DEBUG CLS,"Press a key ",CR,"to bring up menu"
DEBUGIN DEC1 temp
PAUSE 50
IF (temp <>0) THEN temp=0 : GOTO invoke
IF (temp=0) THEN GOTO wait_for_invoke
invoke:
xa_mem = $0 : xb_mem = $7 : xc_mem = $E : xd_mem = $15 '-------------------------------main menu buttons/background/title bar
title = $C4
print_menu: '-----------------------------------------------------------------------------bring up menu system
temp=0
FOR cnt = $F6 TO $143 '-----------------------------------------------print background
READ cnt,char
DEBUG char
NEXT
DEBUG HOME
titlebar: '-----------------------------------------------print title bar
x_mem =0
temp = 16 + title
FOR cnt = title TO temp
READ cnt,char
IF (char=0)THEN EXIT
DEBUG char
x_mem = x_mem + 1
NEXT
temp = 0
PAUSE 25
'-------------------------------------------------------------FILL remaining title bar
temp = 16 - x_mem
FOR x_mem = 1 TO temp STEP 2
DEBUG "_ "
NEXT
'---------------------------------------------------------------------print buttons
temp=0
FOR cnt = 0 TO 3
LOOKUP xloc,[noparse][[/noparse]0,9,0,9],x
LOOKUP yloc,[noparse][[/noparse]2,2,5,5],y
DEBUG CRSRXY, x,y
IF (x=0 AND y=2)THEN x_mem = xa_mem
IF (x=9 AND y=2)THEN x_mem = xb_mem
IF (x=0 AND y=5)THEN x_mem = xc_mem
IF (x=9 AND y=5)THEN x_mem = xd_mem
FOR temp = 1 TO 7
READ x_mem,char
DEBUG char
x_mem = x_mem + 1
NEXT
xloc = xloc + 1
yloc = yloc + 1
NEXT
'----------------------------------------------------------------------------get menu input
wait_for_menu:
sub_menu =0
IF (menu > 0) THEN GOTO wait_for_sub_menu
DO UNTIL (menu <>0)
DEBUGIN DEC1 menu
IF (menu<>0)THEN GOTO decode_menu
PAUSE 100
LOOP
wait_for_sub_menu:
sub_menu =0
DO UNTIL (sub_menu <>0)
DEBUGIN sub_menu
IF (sub_menu <> 0) THEN GOTO decode_menu
PAUSE 100
LOOP
decode_menu:'--------------------------------------------- decide which menu to print next
IF (menu >0 AND sub_menu =0) THEN
SELECT menu
CASE 1
xa_mem = $1d
xb_mem = $23
xc_mem = $2a
xd_mem = $31
title = $ce
PAUSE 25
GOTO print_menu
CASE ELSE
DEBUG CLS,"Menu not made"
PAUSE 2000
ENDSELECT
ELSEIF (menu > 0 AND sub_menu > 0) THEN
SELECT sub_menu
CASE 1
xa_mem =$38
xb_mem =$3f
xc_mem =$45
xd_mem =$4c
title =$ce
PAUSE 25
GOTO print_menu
CASE ELSE
DEBUG CLS, "menu not made"
PAUSE 2000
ENDSELECT
ENDIF
PAUSE 2000
DEBUG CLS
END
