Need help finding datasheet
![TC](https://forums.parallax.com/uploads/userpics/960/n1TI3FP1FAD2X.jpg)
I Bought a Noritake VFD Display (PN GU112x16G-7003) The same display Parallax is selling. I am having troble finding the FULL datasheet, And noitake will not send me one because I did not buy it from them (got it from flea market for $20.00, cant beat it). The display works using Parallax demo programs. I have the short verision. and I have done different things with it. But I would like to know if there is more that I could do. I have looked all over the web with no luck.
So if anyone could help, you would be a life saver
TC
If this is in the wrong Forum, sorry.
TC
·· There will be more example programs for the Noritake Display very soon from us.
csavage@parallax.com
Thank You
TC
·· For the display to go higher jumper pads need to be changed on it.
TC
Post Edited (TC) : 7/12/2006 4:54:36 AM GMT
·· I understand that...We are going to·release some demo codes that focus on the various functions of the display while documenting the details of those functions.· Changes to the hardware probably won't be addressed.· The display has other capabilities and functions related to serial communication as well but for our purposes the default settings of the display are what we will address.· Same with the demo code.
··· I don't believe you will see any significant increase in speed of the display between 38.4K and 115.2K due to internal processing times for some functions.· If you need super high-speed you would then use the SPI interface, which again, we're probably not going to cover.· Bear with me though and I will see about getting those demos done as quickly as possible.· Take care.
I will be counting the days for the demo codes...........DONE YET?
I do have one simple but maby a stupid question. On VFD-demo-02.bs2, Why did you have to do two data's for one picture? should it be just 112 bytes wide? and why are they shifted?
Also on VFD-demo-01.bs2, line 63,
"SEROUT VFD, Baud, [noparse][[/noparse]$0C, " Parallax, Inc.", $0A, $0D, "Microcontrollers"]"
There might be a little glitch (or it is my display). Display says "Parallax, Inc.i", It seams the display is not moving to the next line. All I did to fix it is add a space after Parallax, Inc." If it is a glitch just wanted to let you know so others don't have this problem. But If it is just with my display then, sorry for wasting your time.
TC
·· The reason there are 2 DATA bytes for each column is that they're 16 pixels wide.· That takes 2 bytes to do times the width of the picture.· As for the other problem I will check into that tomorrow...I didn't have that issue on my display, but I will see what happens.· Thanks for the feedback.
TC
········· Even lines·························· Odd lines
%00000000, %00000000,····· %00000000, %00000000
Thanks for your help with every thing
TC
