Pet Feeding System
To anyone who may be able to help,
··········· My name is Dr. Derek Osterheld. I have been pursuing an idea for some time now and am in the patent process but before I invest more money I need to know that a critical aspect of this project is possible and practical. I am a veterinarian; my project is an individualized feeding system. A prototype was constructed for me by DeVry. My problem is that the feeding systems success is predicated on its ability to feed the intended pet and not the other pets in the house - similar to the automatic dog doors already in pet stores. ·The premise is that each pet in the house has its own feeder.·Each individual·feeder is only accessible to the intended pet when that pet is with in a certain distance. Otherwise the feeding systems doors are closed to all other pets. This requires that the receiver on the feeding system picks up the collar tag transmitter only at very close distances so that you can’t have the intended pet sleeping close to the feeder – which opens the feeder doors to the rest of the hungry pets. Below are some target distances for pets of 3 different sizes - which mean 3 different sized feeding systems.
Cats and small dogs shouldn’t activate (open) the feeding doors any further out than 30cm
Medium sized dogs shouldn’t activate (open) the feeding doors any further out than 45cm
Large dogs shouldn’t activate (open) the feeding doors any further out than 60cm
These distances are not written in stone but are at least very close. Reading out 3 feet or further would be useless – especially for cats. No information needs to transfer between the receiver and the transmitter other than·that which tells the receiver that the transmitter is with in the desired range. Additionally, as the transmitter would be located on a pet’s collar it would be best if the transmitter was some what sturdy and did not need a power source or at least was powered by a very small battery.
Please let me know if this is at all possible and of course monetarily practical. Obviously as a consumer product the less expensive the transmitter / receiver unit is the more people would buy it.
Thank You very much for any assistance you can provide.
Sincerely,
Derek Osterheld
knyndoc@cox.net
Post Edited By Moderator (Chris Savage (Parallax)) : 7/11/2006 5:44:54 AM GMT
Sincerely,
Derek Osterheld
knyndoc@cox.net
1) Using an RFID tag on a cat that hates his collar and will spend hours trying to get it off. Considering the general size of a passive tag, attaching it to his collar and him keeping it on there will be a challenge.
2) Extremely skittish animal - the door thing will not work for one of my cats, he simply would refuse to go inside, much less have anything rest on him, close behind him, etc. As such, I've looked at just having something to release a few kibble to him at most every ten minutes he's around (assuming the presence issue above is solved.)
3) Extremely smart 2nd cat - she will figure out any given device and try to disable it - this also limits simple door mechanisms as she'd simply paw it enough to get it open.
4) Sturdiness - either the 2nd cat or the dog can't be able to force their way through the system, much less destroy the electronics in the process.
I have a feeling you'll get some buyers but it's kind of like the automatic litter boxes - a lot of cats simply won't use them due to fear - and fear of the litter box is not something you want....
Thanks Again,
Derek Osterheld
