Intel Macintosh
I have been using the Basic Stamp with my old G4 Mac OSX tiger, Recently I upgraded to the new Intel chip also with Tiger, however I can not get the tokenizer.shlb to be seen by the MacBS2 program and hence it can not see the BoeBot on the USB Port.
I have tried different versions of the tokenizer.shlb and also of the FTDIUSBserialdriver.kext but the solution evades me. Any one with any suggestions.
Craig
New Zealand
Craig
New Zealand
Intel Mac OS X FTDI USB Driver - Requires 10.4 (Tiger) Version 2.2.0
Found a driver here
http://www.blackcatsystems.com/usbciv/
This works fine.
http://www.ftdichip.com/Drivers/VCP.htm
I wouldn't connect that if I were you...
I have both a mac and a PC and I think the PC software is just better, at least in the debug department and the check syntax.
let me know if you need a temp 30 day trial serial I have one.
Basic Stamp Editor and FTDI drivers within Windows 2K Pro inside a Parallels virtual machine on an Intel Mac works.
Long Answer:
I have a Mac mini Intel Core Duo on my electronics workbench and have been using the MacBS2 app on it very successfully. I do like many features of the Windows Basic Stamp Editor but I prefer the MacBS2 app mostly because it operates on my preferred platform. I do work cross-platform though so getting Parallels installed on the mini and Windows running within it wasn't even a question for me.
After I installed Parallels I created a Win 2K Pro virtual machine on it. With the FTDI drivers installed under Mac OS X, Parallels was unable to get access to the FTDI USB ports and I was initially unable to install the FTDI drivers in the Win 2K Pro vm (Windows doesn't "see" the ports so it never asks trys to auto-install them and the Add Hardware Control Panel can't find the ports either). I disabled the Mac OS X FTDI drivers (just move them out of the
directory and reboot) and Parallels was then able to see the USB ports, make them available to the Win 2K vm, and I was able to install the Windows FTDI drivers. That done, the Windows Basic Stamp Editor worked as expected.
I have a Professional Development Board, a BOE, and several BS2 OEM boards (the latter connected via a Keyspan USB-to-serial converter). Both of the USB-based boards work well with MacBS2 as well as the Windows Basic Stamp Editor (though not at the same time for the driver-based reason explained above). I did not test the Keyspan driver in the Parallels Win 2K Pro vm so I do not know for a fact that it works but I would expect it to since I was able to get the FTDI drivers to work.
I haven't tested Windows XP Home or Pro but I expect that either should work given the general similarities between Win 2K and Win XP.
Vive Le Tour!
July 1 - July 23
Post Edited (aalegado) : 7/12/2006 5:14:33 AM GMT
http://www.macwindows.com/
I've got the adapter showing up in XP in Parallels just fine, but it doesn't show up in the SXkey-v3.2 software, the list of Serial ports is empty.
I'm using the latest Keyspan drivers.
Do I need different drivers, or must I buy a different USB to Serial adapter?
I've spent a whole day getting XP installed and up to date... anxious to get this working. Very frustrating...
Dave
·· This message should be in the SX Forum, and you should start a new thread.· Take care.
csavage@parallax.com
I just got an intel mac, and i have a beklin USB to serial adapter f5u109,I am using the newest version of macbs2, but under ports there are none. can anyone give me any ideas on what i can do. Or if the usb to serial adapter i have will even work. Thanks for your help, I am new to the whole mac world so please bare with me
Thanks Justin
