Simple "On-Off" technique for the Homework Board
I have been using a Parallax Homework board for some time. I had built a battery enclosure with a switch that led to a nine volt connector to hook up to the board. Recently I started simply snapping in only the + side of the nine volt battery to the terminal on the board, and by simply twisting the battery down or up, I turn the board on or off. This overcomes the shortcoming of this board, no power switch... This works well for non-mobile applications, where there is no vibration. Simple, and saves wear and tear on the battery terminals on the board....
Ron Giuntini
San Francisco
Ron Giuntini
San Francisco
If you have questions about the power supply, send an email to tech support.
ResetOnOff DATA 0
temp var byte
READ ResetOnOff, temp
temp = temp + 1
WRITE ResetOnOff, temp
IF temp.BIT0 = 0 THEN END
