Optoisolators
Hello everyone,
I plan to isolate my stamp from a 12vdc source by using optoisolators.· I origionally planned to use a 4n35 simply because I found an example circuit on the Parallax site to step the voltage down and isolate the BS2 from a 12vdc source.· I went to Jameco to order some and discovered they have over 100 optoisolators/couplers.· Not all of them are 4n35s, but I don't know what to look for.· What specs do I need to look for when choosing such an isolator?· Is it really critical?
Also, I will need about 12 of these circuits for 12 inputs.· Does anyone make an array of these isolators·so I won't have to have 12 ICs, 12 resistors (all example circuits i have seen use a resistor), etc?
To give you a rundown on what this is for; I am programming BS2 for control of automotive accessories in a 10-15VDC environment· I plan to use:
12 12VDC inputs isolated with the optoisolators mentioned above
8 high current 12VDC outputs using DC-16 for relays, solenoids, etc
1 high current 12VDC motor control using a couple of·MOSFET transitors and PWM to drive a 25 amp 12VDC motor
Any obvious problems with this setup?· Am I missing anything?
Thanks!
Thanks!
·· I don't know if these are still made, but this guy used a bunch of Optos in an Electric Car Battery Monitor.· He lists the part number he used for monitoring/isolating the 12V from the A/D converter.
http://genki.home.ionet.net/BattMon/BattMonArticle.html
csavage@parallax.com
Thanks for the info.· After I posted my question, I bumped around on Jameco's site for a little while and found these:
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=273607
and
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=320830
These look like they will work as far as having multiple isolators in a single package, but I am unsure about their electrical characteristics.· "Forward Voltage" and "Reverse Current" is just jibber jabber to my mechanical mind...
R = (VIN - VLED) / ILED
This will give you the value of the resistor you need.· R = Resistor Value in Ohms.· VIN is the car voltage.· VLED is the Forward Voltage of the LED.· ILED is the forward current of the LED (No maximum, but nominal).
The other thing you want (for ease of use) is an NPN on the output.· This will provide good interface to your I/O pin and, depending on the Opto may require only a 10K pull-up resistor.· I recently posted an Opto Diagram that is essentially the same as what's in the isolator.· See this thread...I hope this helps.
http://forums.parallax.com/showthread.php?p=594783
http://www.bgmicro.com/prodinfo.asp?sid=0808032407407407701761198&prodid=ICS4N35&page=1&cri=4N35&stype=3
I certainly wouldn't try to put 32I/O's through a 32 opto isolated array (if one was produced).....I'm more apt to pair off groups of signals to isolate.
Steve
·· Since they're isolated it shouldn't be a problem.· Although I have to admit, all the ones I have used are single units, such as the classic TIL111...I think that was the part...age...
To me, it makes more sense to spend $1 (or whatever) on 20 opto's and have to replace individual ones when they go, rather than paying $6 for a multi one and having to replace that whole multi-array when a single opto fails.
Steve
·· Makes sense...I used 4 of the TIL111s before in one board, so...I certainly understand your point.· Take care.
Of course, these are all DIP and in sockets. Otherwise, you find yourself with significant downtime.
BTW, if the Stamp can drive an appropriate 5V relay via a darlington or FET, you can exploit the·'mechanical isolation' of the relay on the 12volt side.· The darlington or FET would likely be the failure component if their were a short circuit, so you achieve the same thing [noparse][[/noparse]protecting the BasicStamp], but without 'complete' isolation.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Post Edited (Kramer) : 7/9/2006 10:36:12 AM GMT
Chris,
You mentioned I will want a NPN for ease of use.· Why is this?· I think of everything as mechanical, but I thought a NPN transistor acts basically as a relay - apply voltage to the base and current and voltage flows through.· Thats basically the same thing I am doing with the optoisolator.· Why do I need to do it again?· Is it a polarity thing?· If so, why can't I change the polarity at the optoisolator collector?
I am sorry for these questions that seem simple to everyone else, but I am SLOWLY learning.
Thanks!
Thank you again for the info. I guess my real question is, why can't I use a BS2 input pin to read directly from the output of the optoisolator instead of sending it through the transistor to switch it from a high input to a low input signal? That is the purpose of the npn transistor, correct?
Thanks!
Ok, to add another dumb question to the mix, I have found 2 different configurations of photoresistors (at least in the single packages).· One I know is an NPN, the other I think it is by looking at the arrow, but I am not sure b/c it does not say.
1st one:
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=40985
2nd one:
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=320813
The first one is the standard optoisolator.· What is pin 6 used for?· It appears to be the base of the transistor, but isn't that supposed to be all contained internally and "turn on" only when the internal LED is on?· If so, will pin 6 just not be used in my circuit, or am I missing something?
Thanks!
Okay the second one is NPN as well.· And easy way to remember by the diagram (This is how I learned) is that the arrow always points to the N channel and is always the emitter.
In the case of using an Opto-Isolator, the NPN vs. PNP preference sort of gets tossed out the window. This is primarily due to the isolation of the transistor "gate".
You can think of an Opto with a transistor output (NPN or PNP) as a "gated" diode. When the transistor is "ON" (Input LED is ON) the connecting circuit sees a
diode across the C-E junction. When the transistor is "OFF" (Input LED is OFF) the connecting circuit sees an open circuit.
The problem with using a PNP is when you do NOT have gate isolation, and you have to consider that the B-E junction acts like a diode regardless of the transistor
being turned ON or OFF. The main concern only happens if you are trying to switch different supply voltage levels.
The link below explains this a little bit...
http://forums.parallax.com/showthread.php?p=552069
Beau Schwabe
IC Layout Engineer
·· Yeah, I don't recall ever seeing a PNP-based opto...Nor have I used one, so I don't really have any experience with their usage, although, as the OP linked, some have the base brought out to a pin and can act as a standard transistor on the output side.· I believe we used the base lead in a few applications to sort or pre-bias the output to a certain level when no input was present.· Being the transistor guru we should get a tutorial by you and make it a sticky thread in the Sandbox or something.·
On the Opto usage note: I have used DigiKey's 25xx and 27xx series Opto's in the past with satisfying results....
And as a side note, at least on the Quad Opto versions, if you blow the LED on the input or the transistor on the
output, the other Opto's "seem" to be unaffected.
Beau Schwabe
IC Layout Engineer
Here is a curcuit I find works great for my experiments, You can use PNP Proximity, NPN Proximity,Open Collector Photo-Transistor or a panel switch by jumpering the selected header. I am currently useing this for my Propeller Tru PLC functionality project. The output is 24vdc and can handle 1 amp. The drawnings were created on Express.PCB. My labtop motherboard died last week so I only have hard copies of my paperwork until I can get my labtop repaired or the hard drive copied. The Input board is 5 volt input, with the output·you can change the resistor for any voltage you need.
Enjoy,
Rob7
A Pic Of my Output PLC 24V board. The schematic is displayed on the previous post.
Rob7
A big thunder storm came through today and our radar tower got tagged a few times. Everything went wonky!
Some things were opto-isolated....some weren't....the things that weren't...RIP! The things that were, well, although they suffered damage and are basically useless, they did protect downstream equipment.
So that little $2 MOV or what-have-you is definately worth saving 1000's on the equipment that didn't go up!
it was a really cool storm. I had walked in to the room where the conduits came through the wall and a flash of light lit up the window followed by a huge boom. I dam near pooped myself! haha
Just remember the other 'poor-mans' isolation component.
Tranzorbs....they come in various voltage ratings.
Basically they look like diode's (and I suppose they act like them) and they are designed to short to ground when the voltage rises above their rating.
I can't remember if they're a one time use, but I've certainly seen some that just had the leads left in place (big poof)!
Steve
Post Edited (steve_b) : 7/11/2006 1:40:51 PM GMT
