Cap Value
What should the value of C1 be? I got this from the LM338K datasheet but it does not say.
Well well, I'm seeing things, three of them.
-Stanley Blystone
-Stanley Blystone
-Stanley Blystone
A smoothing capacitor IS totally needed for the Input, but it isn't shown on your schematic.· 3300uF is likely fine; if·with higher current demand you find that your input ripple increases significantly then you'll benefit from more capacitance.
(Are we gonna fish or cut bait here?)
-Stanley Blystone
Although the LM138 (LM338) is stable with no output capacitors, like any feedback circuit, certain values of external capacitance can cause excessive ringing.· This occurs with values between 500 - 5000pF.· A 1uF solid tantalum (or 25uF aluminum electrolytic) on the output swamps this effect and insures stability.
Not exactly -- C1 has nothing to do with the input (filtering/smoothing/stand-up) cap. If you're asking about the input (filtering/smoothing/stand-up) cap... use a scope or an AC voltmeter to monitor ripple vs. output current.· If the ripple is significant, such that·it affects regulation, then add more capacitance (1000uF.)·
You don't want to go hog wild with the capacitors, because a large, uncharged cap makes for a big current spike at power-up (turn-on), which, over time,·could be hard on your transformer, bridge rectifier, and fuse.
-Stanley Blystone
As I replied previously, you can (also) use an AC voltmeter (a DMM set to "ACV") to measure ripple on the input, or anywhere else, if that is an over-arching concern.· [noparse][[/noparse]N.B. -- low-frequency AC, 60Hz, 120Hz; not spikes or high-freq.]
Lives aren't at stake -- Relax.
-Stanley Blystone
