Bob Blick's H-bridge is pretty hefty.
Parallax's HB-25 is a really good investment for power.
The 'Tilden Bridge' is for a very small motor, a battery powered toy motor. Usually 1.5 to 6.0 volts
Only 6 transistors and 2 resistors. 2n3904 and 2n3906 transistors.
Instead of a circuit board, you epoxy the six transitors together and then very carefully bend and twist wires according to the pictures. And finally a touch of solder on each connection. Kind of looks like a tiny six pak of flat sided beer cans.
Google for it if that is your size.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
See if this helps:
http://www.bobblick.com/techref/projects/hbridge/hbridge.html
Bruce Bates
<!--StartFragment -->
Here's a single chip (SN754410) solution with schematic to BS2:
http://www.bio-bot.com/privateweb/datasheets/powercontrol/SN754410app1.htm
JG
NerdMaster
For
Life
