STAMP to SX
I have developed an application using a STAMP and would like to convert this into a SX based unit.
It is a pretty basic project incorporating a g-meter and BCD. Upon start-up the STAMP reads the BCD to set a g-force threshold. Then the STAMP constantly samples the g-meter. If the G-force exceeds the threshold..an output is turned on until the g-force drops below the threshold. Then it is turned off.
I am in the middle of a few other projects and don't have the time to learn the SX. Would anyone be interested in converting this code for me in return for compensation?
Toby
Toby
How about for free in this forum?
Please specify the number of BCD digits, and the method of "sampling" (serial, paralell, or ???) the G-meter, and the rates at which these are to occur. Also the signal levels; hopefully 5 Volts.
On the surface, sounds pretty simple; but you never know.......
Please post a schematic of STAMP circuit if you have one.
Cheers,
Peter (pjv)
Also, would you be willing to attach the current Stamp program you have written for the G-Meter? This will help give the forum members a good idea of the operation of your application.
Thank-you,
Alan
"I learn when I succeed, but I learn more when I fail."
Thanks again
Looks pretty simple.
Your description is somewhat different from what the STAMP code (tilt vs acceleration as example), and schematic (more features such as A/D) would imply. I take it that your simpler description is what's needed?
Cheers,
Peter (pjv)
Good observations. I am measuring tilt using the G-Meter. The BCD value determines the threshold tilt value. Once the threshold is met, the output turns on until the tilt is below the threshold. The boards is a dual purpose board. Ignore the A/D.
Toby
