Power Supply
whitelancer
To anyone that can help,
I have set up two battery packs for power on my robot. One pack is 9V and runs the Javelin Stamp. The other is 6V and powers the motors and motor controller. All the batteries are lithium 1000 mAh batteries. The two packs have been grounded together and yet I am still have trouble getting the motors to run. I was wondering if anyone had any suggestions to help me out. Thank you!
Sincerely,
Jon
Sincerely,
Jon
I thought lithium has high capacity with small volume, but
the drawback was a lower current output.
Have you tried ordinary batteries for your motors?
What code do you use?
regards peter
Sincerely,
Jon
(probably less due to voltage drop)
NiMH is probably better suited for the job, larger capacity and cheap chargers.
regards peter
Jon
That gives you 3 times your current capacity.
http://www.thomas-distributing.com/index.htm
regards peter
Sincerely,
