SX Brownout
Mag748
I have an SX project that works fine if I use a 9V 1500MA power supply, but the power regulator that I am using gets extremely hot. I measured the·current usage which turned out to be about 600MA,·So I went and got a 6V 800 MA power supply and tried it out, but the SX does not run. The power going to the regulator is about 6.5 V and the power at the SX is 4.7V. the brownout is set at 4.2 V, so why is the SX not running? I have a brightness control on the LEDs that I am using, and when I lower the brightness, the SX jumps into action. So, I am pretty sure the brownout thing is causeing the problem.
Thanks for any explanation as to what is going on.
-Marcus
-Marcus
csavage@parallax.com
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"I'm a man, but I can change, if I have to, I guess" The Red Green Show
Marcus
You may get it to work somewhat, but you need a LM2940-5.0 for 5 volt operation as it drops out at 5.5volts or so.
Setting the SX to 2.6V brownout and using an LM2940-3.3 will operate at 3.3volts - BUT you need the 3.3 volt Programing adapter for the SX-key.
Don't turn off the brownout feature unless you have engineered a very stable power supply. Otherwise, you may just have the SX turn on and off continously.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Bean.
This brings up an interesting point...Running a regulator such as the 7805 at its maximum (not absolute) input voltage and drawing maximum current (1A) a standard TO-220 heatsink is insufficient to keep it cool.· You need something hefty in that case, and in one case I have seen the 7805 go into thermal runaway when it didn't have a heatsink.
Well well, I'm seeing things, three of them.
-Stanley Blystone
