converting BS1 code to BS2
I hope this is a simple question. Does the code below make sence the way I conveted it??
The BS1 Code:
symbol dat = b2
symbol synch = b3
symbol junk = b4
synch = "A"
junk = 126
start:
pause 1000
for dat = 1 to 255
serout 0,N2400,(junk,synch,dat)
pause 50
next
serout 0,N2400,(junk,synch,0)
goto start
The BS2 Code:
dat VAR Byte
synch VAR Byte
junk VAR Byte
synch = "A"
junk = 126
BAUD CON 16780 'N2400 baud (MAX)
start:
PAUSE 1000
FOR dat = 1 TO 255
SEROUT 0,BAUD,[noparse][[/noparse]junk,synch,dat]
PAUSE 50
NEXT
SEROUT 0,BAUD,[noparse][[/noparse]junk,synch,0]
GOTO start
I'm using this code for a pair of TWS-434 RF transmitter, and RWS-434 RF receiver. I can't seem to get it right and the receiver is just turning on the LED's at random. Thanks for your help!
Nick
I'm just 10 people short of a threesome!!
The BS1 Code:
symbol dat = b2
symbol synch = b3
symbol junk = b4
synch = "A"
junk = 126
start:
pause 1000
for dat = 1 to 255
pause 50
next
goto start
The BS2 Code:
dat VAR Byte
synch VAR Byte
junk VAR Byte
synch = "A"
junk = 126
start:
PAUSE 1000
FOR dat = 1 TO 255
PAUSE 50
NEXT
GOTO start
Nick
·· The conversion looks fine.· What data are you getting for what you send?· Are you sure the data is inverted?· Have you tried true baud mode (396)?·
csavage@parallax.com
