Propeller and Elexol Ether I/O 24 Interface?
Bill Chennault
All--
I'm a newbie with very little electronics background. (Computer guy.) I would like to interface a Propeller (or one of the higher-end Stamps) to an Elexol Ether I/O 24 (http://www.elexol.com/Downloads/EtherIO24DS1.pdf).
Do you have any ideas how I might go about this?
Thanks!
--Bill
Thanks!
--Bill
Can you describe what your "big picture" goal is? That should help you get some more specific advice.
OS-X: because making Unix user-friendly was easier than debugging Windows
links:
My band's website
Our album on the iTunes Music Store
What I REALLY want to do is add a lot of I/O ports to the Ether I/O 24 and be able to sense my machine's every joint. Like you implied, I want the real processing to be done by a PC . . . via WiFi. The problem is that the Ether I/O 24 does not come in a wireless version. I have suggested it to Elexol and they like the idea, but that is then and this is now.
Therefore, I figured worst case I could still get a wireless PC--or a network of them--to do the processing for me if I lugged an access point around in the robot. One thing leads to another. Pretty soon I figured (maybe incorrectly) that the access point would either need at least four Ether I/O 24 modules·attached to it via Cat 5 to give me 96 ports, or a bunch of daisy chainable (USB) serial modules. As far as I can determine, the serial modules will need a microcontroller to identify their unique serial numbers; then the bit-on, bit-off status would become easily determinable for each module. Since the USB serial modules are cheaper than the Ether I/O 24, I thought I would go the microcontroller route for added flexibility. (Plus, I would learn a lot more, which is very important to me.)
However, you are right, the robot with an onboard access point and four Ether I/O 24 modules would do the trick. If you have any comments, I am more than eager to read them.
--Bill
You are what you write.
http://www.lantronix.com/device-networking/embedded-device-servers/wiport.html
http://www.lantronix.com/device-networking/embedded-device-servers/wiport-nr.html
Many, MANY thanks!
--Bill
Good luck with the project!
