Capacitor trimmer or use a POT
My son plays guitar and wants me to do a mod on one of them. The mod calls for a 4 way switch to switch between 4 different capacitors rangeing from 33pf to 330pf.
Could I use two 10-180pf capacitor trimpots in parallel with 2 knobs to get a 20 to 360 pf range? one knob from 20 to 190 then the other would increase another 160 (20 to 180)
Could I use a 450pf cap and a Potentiometer to vary the amount of leakage from the cap to create a much more variable capacitor range?
Think outside the BOX!
Seems to me that the 'capacitor trimpots' cannnot attach to knobs. So one might have to fool with a screwdriver to adjust them.
I suspect the original design considered all this and decided that the 4-way switch was more reliable. If you want more selection, a 10-way or 16-way switch [noparse][[/noparse]the thumb wheel variety] might be easier during actual performance.
You would have to run some trials to find the right design for you.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Post Edited (Kramer) : 7/6/2006 1:57:41 PM GMT
For the moment, I'm just going to refer to this device as a "black box". What were you hoping the output of the black box would be:
Pos 1· Pos 2· Pos 3· Pos 4
33 pf 133 pf 233 pf 330 pf
or some other set of values? Those above are just evenly spaced between your endpoints of 33 pf and 330 pf.
Regards.
Bruce Bates
<!--StartFragment -->
Post Edited (PJ Allen) : 7/6/2006 1:21:01 PM GMT
That is why I am wondering if for example a WAW pedal could be used as a variable resistor to bleed power from a larger cap making a variable capacitor. I don't know how the bleed resistor would affect the rest of the circuit and I have not explored the math as to what values are necessary.
Thinking about that to get some very weird sounds (Outside the box here) one could one simply hook up a wire connected to your body as a variable capacitor? These things are running on 9V batterys so no danger of shocks.
Yes the dinky trimpots I looked at on digikey are about 6 bucks and dont have knobs however it looks like a sturdy brass or metal turning post that a knob could be attached.
A quote from another site
Perhaps one can make a capacitor from dissimilar materials and slide them over each other to create the capacitance needed for this specific range?
Additional thoughts brain notions far fetched unconventional thoughts? - Outside the box of course.....
Post Edited (metron9) : 7/6/2006 1:24:04 PM GMT
