Reading PINS in a loop?
Vern Graner
Ok, in one of my hare-brained schemes, I'm trying to read a sequence of pins and then act on the values. My original code had big repeating chunks such as this:
So, I envisioned saving memspace and being more efficient by putting this inside a FOR/NEXT loop like this:
However, (and maybe I'm a victim of cerebral flatulence here) I can't find a way to use a variable for a pin number! (the above was my first test and it didn't work)
Can someone give me a kick in the shins in the right direction? TIA! [noparse]:)[/noparse]
Vern
PS:
Post Edited (Vern) : 7/6/2006 12:16:44 AM GMT
IF PIN1 = 1 THEN SEROUT DC16, DC16Baud, [noparse][[/noparse]"!DC16", DC16Addr, "P", 1, TurnOn] ELSE SEROUT DC16, DC16Baud, [noparse][[/noparse]"!DC16", DC16Addr, "P", 1, TurnOff] ENDIF IF PIN2 = 1 THEN SEROUT DC16, DC16Baud, [noparse][[/noparse]"!DC16", DC16Addr, "P", 2, TurnOn] ELSE SEROUT DC16, DC16Baud, [noparse][[/noparse]"!DC16", DC16Addr, "P", 2, TurnOff] ENDIF IF PIN3 = 1 THEN SEROUT DC16, DC16Baud, [noparse][[/noparse]"!DC16", DC16Addr, "P", 3, TurnOn] ELSE SEROUT DC16, DC16Baud, [noparse][[/noparse]"!DC16", DC16Addr, "P", 3, TurnOff] ENDIF IF PIN3 = 1 THEN SEROUT DC16, DC16Baud, [noparse][[/noparse]"!DC16", DC16Addr, "P", 4, TurnOn] ELSE SEROUT DC16, DC16Baud, [noparse][[/noparse]"!DC16", DC16Addr, "P", 4, TurnOff] ENDIF
FOR cntI = 1 to 4
IF PIN cntI = 1 THEN
SEROUT DC16, DC16Baud, [noparse][[/noparse]"!DC16", DC16Addr, "P", cntI, TurnOn]
ELSE
SEROUT DC16, DC16Baud, [noparse][[/noparse]"!DC16", DC16Addr, "P", cntI, TurnOff]
ENDIF
NEXT
Can someone give me a kick in the shins in the right direction? TIA! [noparse]:)[/noparse]Vern
PS:
Vern Graner CNE/CNA/SSE | "If the network is down, then you're Senior Systems Engineer | obviously incompetent so why are we Texas Information Services | paying you? Of course,if the network http://www.txis.com | is up, then we obviously don't need Austin Office 512 328-8947 | you, so why are we paying you?" ©VLG
·· Can you clarify...Are you trying to make the outputs of the DC-16 match the inputs at 4 Stamp I/O pins?· If so that can be done with 1 or 2 lines of code.· You're using the P command on the DC-16 to set a pin, but you can set them all at the same time with the S command.· Likewise you can read the pins at the same time on the BASIC Stamp using the IN<register> command, such as INA.· The PIN statement only allows you to define constants, so you can't use it in a variable environment.
BTW - Congrats on your 2nd Nuts & Volts article.
csavage@parallax.com
I originally wrote large repeating code hunks like this:
So I envisioned putting it in a loop like this:
FOR cntI = 1 to 4 IF {pin number <a variable>} = 1 THEN <do some stuff> ENDIF NEXTI'm trying to determine how to use a pin# in a comparison, but where the pin number itself is specified in a variable...? Is this possible?
Thanks! Couldn't have done it without you guys!
Vern
·· I think I see what you want, but in your condensed code you're executing the same code if any of the 4 pins are high.· If that is what you want, you can do that a much easier way...Please let me know if I am on the wrong track here...
If your pins are P0-P3 then you could say:
Status···· VAR···· INA
later in your code, you could do this...
IF Status THEN
·· <do stuff here>
ENDIF
In this case, if any pin was HIGH, then the <stuff> would get executed.· Is that what you mean?
Dang. Nope.. again, my bad. (I really suck at describing what I'm looking for!)
The idea is to condense the above into a FOR/NEXT loop where I use a variable to represent the pin number I'm trying to sample ie:
FOR cntI = 1 to 3 IF {pin number <cntI>} = 1 THEN <turn on light(cntI)> <play sound(cntI)> <move servo(cntI) to home position> ENDIF NEXTWhere the command in brackets above is what I'm looking for... Any clearer?
Vern
·· I will clear my head at work tomorrow and rethink this...I think my brain just turned to mush!
You can address pins by index as follows:
IF IN0(cntI) = 1 THEN ...
For example IN0(5) is the same as IN5.
Tracy Allen
www.emesystems.com
·· I was trying to think if there was a way to condense his routine so he wouldn't have to handle one event at a time.· Since 4 pins can easily read at once it seems like it would be faster, but handling the resultant routines is what I'm not getting in this case (Sorry Vern, programmers block?).· Any ideas?
FOR cntI = 0 TO 3 IF IN0(cntI) = 1 THEN HIGH 8 + cntI SEROUT PSCPin, Baud+$8000,[noparse][[/noparse]"!SC", 5 + cntI, 0, 750 & $FF, 750 >> 8, CR] ENDIF NEXT▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
OS-X: because making Unix user-friendly was easier than debugging Windows
links:
My band's website
Our album on the iTunes Music Store
It is common to do things such as:
v.bit0(d)
where d is your offset- notice I used "v", because this is just some variable that can be thought of as an array of pins. The DIRS and INS can be treated the same way.
Likewise you can use the different modifiers to just get banks/chunks (such as HIGHBYTE, LOWBYTE, LOWNIB, HIGHNIB, etc)-
Ryan
Ryan Clarke
RClarke@Parallax.com
·· Okay, I think we got a little off-track there...Since there will be different code run based on a pin, and not just some other I/O pin changed you will have to use the FOR...NEXT loop, and Tracy has shown you above how to index the I/O pins in that manner.· I guess technically it won't condense the main body of the code since you will have to spell out the code for each event.· The only way it could be condensed was if each routine did the same exact thing but affected different I/O pins.· Then you could use one piece of comon code and reference the pins from there by index as well.· Sorry for the earlier confusion.· I was trying to solve this from my own perspective.
' ************************ ' * Servo Pump * ' ************************************************************************* FOR cntI = 1 TO 5 IF IN10(cntI) = 0 THEN 'the IN10+cntI value steps from pin11 to pin 15 IF Flag(cntI) = 0 THEN '\ DC16Channel= cntI ' | DC16State=TurnOn ' | GOSUB UpdateDC16 ' | PSCposition = PumpStart ' | PSCchannel = cntI-1 ' | Code runs when button pressed PSCrate = 0 ' | GOSUB MoveServos ' | Flag(cntI)=1 ' | ENDIF '/ ELSE IF Flag(cntI) = 1 THEN '\ DC16Channel= cntI ' | DC16State=TurnOff ' | GOSUB UpdateDC16 ' | PSCposition = PumpStop ' | PSCchannel = cntI-1 ' | PSCrate = 0 ' | Code runs when button released GOSUB MoveServos ' | PaintShots=PaintShots-1 ' | GOSUB UpdateLED ' | Flag(cntI)=0 ' | ENDIF '/ ENDIF NEXTThis code allows me to use the cntI variable to 1) read the pushbutton 2) send a command to the Parallax Serial Servo Controller (PSC) and 3) send a command to the DC-16. Since the DC-16 starts its channels at "1" and the PSC starts its channels at "0" I had to do a "cntI-1" to get the channels to line up, but this seems to work fine. I use the Flag (cntI) to make sure that the command is executed only one time per button press and one timer per button release (there's probably a more efficient way to do this, but I'm just hammering out test code right now, so opionions welcome!).
So, I can now hit and hold any of the buttons to get lights and servos to react in response to input! Thanks again guys!! I love these forums. Keeps me from beating my head against the wall too much..
Vern
