Detect video signal
Hello all,
Is there an easy way to get the BS2 to detect a video signal? All I need it to do is be able to detect a video signal, and if one is present light an LED.
Also I have seen 2 BS2's connected together, what is the MAX length a serial data signal will travel when connecting a 2 BS2's together? Someone had mentioned using·RS485 or something like that. I am·not very familar with serial communications. I will be connecting 250 ft lengths of wire up a max length of 1000ft.
Any help would be appericated.
Patrick
Patrick
· I would use an LM1881 sync seperator. It will output an odd/even signal (as long as the video signal is interlaced) that can be measured with the BS2. The odd/even signal is a 30Hz square wave when video is detected.
· As for connecting two BS2 together, it depends on how fast they need to communicate. For slow communication (2400 baud ?) just wire will work.
Bean
Cheap 4-digit LED display with driver IC·www.hc4led.com
"I'm a man, but I can change, if I have to, I guess" The Red Green Show
csavage@parallax.com
