Running SXes at 75mHz and 3.3volts
Since summer arrived I have more time to·return to using SASM.
This is really an oddball question.
I bought a programming adapter for 3.3volt operation and I am changing the 5V supply on some of my SX48 Protoboards to 3.3v for cool running.· I can easily get up to 50mHz with resonators on hand.
I previously purchased several 75mHz tincan oscillators and I see they are +5V.· One thought is to just run them at 3.3volts, but I suspect that might not work.·
Though I cannot seem to figure a way to run the Protoboard as a dual voltage supply, I am also considering creating another board that might·provide dual voltages·with an SX-28.
Is there any problem with providing +5volts to the oscillator and +3.3 to the Vdd on the SXes?· And, would this really run the devices cooler and with less power consumption?
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
·· You're right, the TTL Oscillator is designed for 5V, but for 3.3V operation you could use a 75 MHz crystal instead, or for 5V, most applications doing this employ at least some passive cooling for the SX48 (see the XGS).· I hope this helps.
csavage@parallax.com
-Dan
