pls help — Parallax Forums
pls help
shinojshinoj Posts: 2
edited 2006-07-08 19:03 in Robotics
i am a student .· i have· bs2 n TX N RX··· i need to jus transmit n recieve somethin to check·..· can u guys tell me how to connect tx to· bs2.. n i want the circuit diagram n the programm codes .. can u guys pls help me...
  • CheetoCheeto Posts: 19
    edited 2006-07-05 19:15
    What going on in this post ? Is "n" a variable or is it short for "and" ? I'm so confused
    edited 2006-07-05 20:02
    You should start by reading the instructions that came with your receiver/transmitter for clues on how they work.
    - Stephen
  • Matt WhiteMatt White Posts: 60
    I would suggest checking out the communications section of Parallax's website.
    http://www.parallax.com/detail.asp?product_id=28180
    What stamp are you using? (BS2, BS2p, etc.).
    What is the exact make/model of the tranismitter and reciever?
    What do you want to communicate with? (e.g. PC, another Stamp, etc.)
    Answers to these questions would help us at least point you in the right direction.
    I would find the datasheets for the devices which should include details on how to use them.· If you can't make sense of the datasheets (there some I have hard time with), I'd suggest purchasing the RF transmitter and receiver directly from Parallax.· You'll find their devices well documented with source code and instructions on how to use them.
    Matt
