PING))) Substitutions
Hi y'all,
I need to measure the level of water in a container. Ultrasonics are the way to go, I think. But I want to protect my sensoir from the water itself. Does anyone have experience with replacing the stock Ping transmitter and receiver with ceramic component?
I've located a couple of sources that would work fine for moisture:
http://www.steminc.com/piezo/airtrans.asp
http://www.hobbyengineering.com/H2209.html
So far, so good. I intend to mount the Tx and Rx seperate from the board, so exact pin spread and sensor diameter is not terribly important. Can someone tell me which is the Tx and which is the Rx on the Ping? Or does it not matter once polarity is established.
Kalo
Failure is not the only punishment for laziness; there is also the success of others.
- Jules Renard
Kalo
- Jules Renard
www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
