Surface Mount Resistor Arrays
I am having a hard time figuring out what resistor network arrays are available. I have a circuit that runs on 5V
I divide that with a 100ohm---->200ohm--->Ground
Between the 100 and 200 ohms I go to 4 resistors
200,400,800,1600
Those are tied to 4 pins PB0...PB3 on a tiny13
The pins are toggled from input, with no pullup, to output LOW to make 15 different voltages that drive a Hexfet Gate.
Is there a 4 pin resistor array I could use in this circuit and how do I go about finding or ordering the correct part.
I dont know what arrays would be standard VS hard to find parts.
Think outside the BOX!
200,400,800,1600
··Stay inside·the BOX!
