RS232 Level Converter
Is it possible to use one of these to program the propeller?
http://www.schmartboard.com/index.asp?page=products_populated&id=84
Or one of these?
http://www.sparkfun.com/commerce/product_info.php?products_id=449
Or should I just stick with the max232?· I would just like a quick easy, prebuilt solution without buying a whole dev board..
Or one of these?
Brian
You would need a level shifter board with handhshake. I have a board coming out in about three weeks that will work. It's the same that I take the user through building in my book. Has full handshake under cpu control. I don't know why but it seems all the new boards lack hardware handshaking. The hardware handshake lines are great for I/O too. So if you can't wait, look for a level shifter board with DTR or hardware handshake enabled.
Oliver
If you are selling boards for this, I would probably buy one, or two.. I am all about saving time and headaches.
Any chance you'll be selling one for prototyping between 5v serial devices? (without the db9, etc..) something that can be used between the propeller and say an emic speech board, or similar embedded device that operates on 5v?
Thanks for the info.
Oliver
