Need Help Configuring my Blue Application Module With my BOE BOT..
I am kinda new at this... i wanted my BOE Bot to communicate with my PC through bluetooth....This is what i got
But i have no clue as to what pin to connect to or what Code to use...As i said a kinda New at this....Can anyone help me out....This is very important for me....I have to finish this thing by end of next month..
Bit of a tall order if your new ?·to this.· Have a look at a project I finished a few months ago using a BOE, Eb500, 100 metre Bluetooth adapter, serial servo driver, dual serial motor driver,·wireless cam, tracked chassis and of course the excellent StampPlot software to make a GUI. In the example on the StampPlot site there should be enough serial BS2 code for you to work around using the Eb500 to communicate with the BS2 and modify for your own project.
http://www.selmaware.com/stampplot/samples/bluetooth_cambot/default.htm
bluetooth-bot-cam.PDF
Good luck
····· Regards
················· ·Stuart
PS.·· Pin wise read the manual for connecting straight in to a Board of Education header
