i give up
everyone says these 555 timers are supposed to be easy and ive tried getting the stupid thing to flash a LED and ive tried about 30 times literally and not once did it do anything.. i cant even read the stupid schematic so either somthing isnt clicking in my brain or this isnt as easy as you guys say it is.
Ron Giuntini
San Francisco
Ron Giuntini
San Francisco
What hardware are you using? A Board of Education? Are you using a "What's a Microcontroller" parts kit?
If you haven't looked at the "What's a Microcontroller" manual, you might want to download it and study the wiring diagrams, and how they relate to the circuit schematics shown.
You might also want to check out a book called Physical Computing: Sensing and Controlling the Physical World with Computers.
Here are some sites related to the book. Look for the basic electronics links on the pages:
tigoe.net/pcomp/intro-pcomp-syllabus.shtml
itp.nyu.edu/~dbo3/physical/physical.html
itp.nyu.edu/physcomp/
You may find that purchasing the following book by Forrest Mims is the best $13.00 you ever spent, insofar as learning about the 555 timer:
http://tinyurl.com/ll8qt
It's also written at the beginner level.
Bruce Bates
<!--StartFragment -->
At the bottom is a link to a 555 tutorial.
http://www.uoguelph.ca/~antoon/circ/555test.htm
regards peter
OS-X: because making Unix user-friendly was easier than debugging Windows
links:
My band's website
Our album on the iTunes Music Store
in another couple months, you'll progress to more advanced circuits....THAT's when you'll look back and think that the 555 is one of the simpler things you worked with.
I honestly don't worry about such devices in how they work internally....just that if I hook things up it does work.
You need to connect one wire at a time.
Are you reading from a schematic (with symbols for the components)? or are you trying to copy from a picture (a view of the resistors/caps/etc sticking in to a breadboard)?
Do some googling on schematic reading....it can get confusing.
What I do is print out the schematic and cross off each component as I install it in my circuit.
This may not be the most efficient way to do it, but it allows me to keep track of large component counts!
Steve
http://www.play-hookey.com/
http://www.uoguelph.ca/~antoon/gadgets/555/555.html is a good place to start. I have no idea what the schematic you have says, but try to remember you only need three parts to make it work (plus the LED or whatever you wish to turn on and off). Don't give up; some day, probably quite soon, not only will you be able to make a 555 work, but you'll be able to confuse the heck out of average·people by explaining how it works!
Edit: Oh! Quick note. If possible, add a second LED in parallel to the first, but reverse it. This way, you can see both sides of the timing cycle, and you'll know if the normal "on" cycle is just too short to see (which was my problem originally). If neither LED lights up, you have a larger problem with the power·connection.
Chicks dig nerds... but not until after the prom.
Post Edited (DigitalMan) : 6/29/2006 1:14:19 PM GMT
All the previous posts offer good suggestions on how to get further along the learning curve. Give yourself some time. Its been almost 50 years since I first got involved with electronics and there's still hardly a day goes by that I don't learn something new.
The greatest thing you can do for yourself is let people know you want to learn. Find a local school tech instructor, a radio-tv guy, a university instructor, R/C airplane club member and ask for help. You will find electronics people more than willing to help you.
Cheers
links:
My band's website
resistor: a zigzag line. There is imformation about resistance, or resisstance...or..whatever, `_`?, in ohms, read the correct resistance of the resistor in the manual. The resistor are color coded, the color code meanings should be in the manual. If not, get a paper, pen, and your resistor and go to your local Radio Shack Store, go to a drawer that says resistors and look for the same color code on a resistor your resistor have. The same color-coded resistor should say the resistance. If you are a good memorizer, you don't have to bring a paper and pen, just memorize the imformation on the package.
LED: an arrow surrounded by a circle and a line blocking the arrow's path. The arrow point is the cathode (the direction where the line is). The anode is the back of the arrow. on a real LED the wire shorter than than the other is the cathode.
I know eight more, but these are the one you need to know to make the LED blink.
I haven't spent much time·working with 555 timers as I'm relatively new to electronics myself.··This is·probably the simplest diagram I could find.· I've included both the diagram·and·a picture of the circuit on my Board of Education.· The only difference between the diagram and the circuit in the picture is I added·a resistor and an LED.
Best of luck!
Matt
here are some great notes on 555
http://home.cogeco.ca/~rpaisley4/LM555.html#5
Ron Giuntini
San Francisco
