Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Boe bot compatibility? — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
General Discussion
bulkhead
405
2006-06-28 19:12
edited 2006-06-28 19:47
in
General Discussion
I have a quick question. Can I just pop off the bs2 from a boe bot and insert a javelin stamp since the pinouts are the same?
Peter Verkaik
3,956
2006-06-28 19:20
edited 2006-06-28 19:20
Yes, but make sure your javelin is cleared (eg. all pins remain inputs)
so any attached hardware cannot harm the javelin.
You can use the attached program to clear the javelin before
it is inserted in the Boe-Bot.
regards peter
java
java
ClearJavelin.java
256B
ClearJavelin.java
256B
bulkhead
405
2006-06-28 19:47
Ok, I am going to try it. Thanks for the quick response!
Sign In
Register
to comment.
regards peter
