Stamp to Stamp
Good Morning Everyone
I have been doing some checking on this and seem to have gotten mixed feelings about the best way to hook two stamps together. I basically want one stamp to send its info to the other stamp and then the 2nd stamp can send the info on to where it needs to be sent. What is your opinion on the best way to accomplish this?
I'm just 10 people short of a threesome!!
If they're on the same board, you already have a common ground, of course.
NerdMaster
For
Life
However, you can wire your own DB-9s -- pin 2(TX), pin 3(RX), and pin 5 (Vss). Then connect the boards that way. And since you have control of which pin of the BS2 talks to which pin of the cable, you can use either a null-modem or straight-through.
