Any Stepper/Encoder experts?
I am designing a circuit to drive a stepper that will be run at low speeds at half steps(400). Because missing a step could be critical, I am thinking of using several products by USDigital. One is an encoder wthat will feed into their own Encoder To Counter Interface IC, which takes the Quadtradture signal on two wires, and outputs Direction and Step Clock output. The concept is to send a step pulse with Pulsout, then read the Encoder Interface Clock output back in on a pin via a SR latch that temporarily holds each output from the IC. That way, the Stamp sends a pulse, the motor moves, results in the encoder putting out a pulse to the interface IC, then the Latch stores the bit. The Stamp will read the bit from the encoder, and allow the next step to pulsout until the specific number of pulses is reached. If one clock does not return from the encoder, the motor stops, and in this case will reverse the motor, as it will be assumed it has been abstructed, and needs to go back to the limit switch at HOME and reset itself. I have never seen code for an encoder, and hoped that somebody may have an idea if this is a workable and reliable concept. The only thing that bugs me is if the EndcoderIn doesnt get back before it looks for the input, but pause times could account for it I suppose. Thanks for any opinions.
Here is a crude idea for programming:
MotorStep VAR OUT0
MotorDir VAR OUT1
Counter VAR WORD
PauseTime VAR NIB 'variable for time between pulses
EncoderIn VAR IN3
EncoderRst VAR OUT2
MotorStep = 1 'active low motor driver input
MotorDir = 0 'move ccw direction active high reset pin
Main:
FOR counter = 1 TO 10000 'move 10000 pulses
PULSOUT EncoderRst, pausetime 'reset encoder latch
PULSOUT MotorStep, PauseTime 'send one pulse out
IF EncoderIn = 0 THEN Problem 'check encoder latch to see if it moved, if not go to problem
NEXT
Problem: 'home motor and reset
MotorStep VAR OUT0
MotorDir VAR OUT1
Counter VAR WORD
EncoderIn VAR IN3
EncoderRst VAR OUT2
Main:
NEXT
You should be able to monitor the current of the motor to see if it is being blocked.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"I reject my reality, and substitute yours." NOT Mythbusters
I may be way off base here, as I'm not sure what you mean by "shunt" above. However, the same current which runs through the + side of the circuit runs through the - side as well. Thus, if due to varying + inputs (as might be the case with a stepper), you can always monitor the - side of the circuit for current.
Bruce Bates
<!--StartFragment -->
Post Edited (Bruce Bates) : 6/28/2006 10:10:08 AM GMT
kelvin
kelvin
Post Edited (kelvin james) : 7/1/2006 5:30:15 PM GMT
I am actually rewriting the Pbasic code to run on the Propeller. I needed to advance to a faster chip, and felt like going ahead with the Spin curve would be worth it in the long run. In the Propellers case, my first attempt is to use a cog to run the basic program for reading buttons, sensors etc, then control the motor driver from another cog, and have a thrid cog always counting and updating a variable that can be read by the main program. USdigital recommended on Friday that I use 1000 pulses (microstepping at 5 x 200) for stepping, and use a 400 resolution encoder. The encoder can output can be x1, x2, or x4, so I can actaully get a higher res (based on rising and falling clocks) off the encoders two tows of lines.
Here is the IC I am using to translate quadreature to up/down counts on seperate pins:
http://www.usdigital.com/products/ls7183-ls7184/
I think it will take some trial and error, as I do want the motor to STOP if it misses a count, assuming that there is an obstruction andto avoid damaged. If there are too many false alarms and there really wasn't an obstruction, then maybe use some method of counting whereas if it misses x pulses, then STOP. Using your method of telling the motor to go, then counting till it gets there will have to be modified to what I prescribed above, which is similar.
Thanks for the advice. I will try to find the Job W post right now, I think that would be very helpful.
