Using many Parallax RF transmitter and one receiver
Hi:
I need to know if possible
to use 6 Parallax RF transmitter (Parallax 433 MHz, Stock#: 27980 )
and one receiver (Parallax 433 MHz RF Receiver, Stock#: 27981 )
If it is not possible to use 6 transmoitters, I could use three of them.
But I don't know if it is possible.
Thanks, Joe
Thanks, Joe
·· I don't think this would work if you're planning on having them all transmit at the same time.· Could you describe what you're trying to do?
csavage@parallax.com
I need to know the possition of 3 robots (or more) using RF.
And then I need to use transmitters and one reciver at the same time.
I hope this can help.
Thanks, Joe
You'll need an accurate timebase to synchronize the robots, and maybe a real time clock for each robot.
You should have the base station send a, report positon, commad to each of the robots one at a time.
Each of the robots and the base station would need a reciever and transmitter.
