Back to the MT8880 DTMF Chip...initialization nightmares
Hi!
Jeez, this is the third time I'm trying to post this...comps kept crashing. So, I finished the hardware side of my circuit, but I have software problems. My board has a weird IO pin scheme, so I cant use the nice nibble approach they use in the NV Column #7. I have to take the number variable apart and write its bits to the pins. My problem is that this code as it is seems to work, but I can change or even remove the initialization lines and it still works (Regardless of what code I use, with or without the "correct" initialization, sometimes I get no tone and sometimes just row or colum tones). My original goal was DTMF decoding, but I guess that won't work until I gte my bits straight. I've been trying to figure it out for a few days, but I can't get it. It may be a dumb error on my part, or it's the lack of understanding of the Stamp's IO variables or the chip's set-up routine.
Oh - I tried to keep pin 5 low all the time...it's connected to ESt on the CM8880 for Detection purposed...it's an input to the Stamp, so I don't know what setting it high would do.
I also keep pins 0,1 and 2 low since they drive a H-Bridge and a serial LCD.
Here is the NV Column #7:
http://www.parallax.com/html_pages/downloads/nvcolumns/Nuts_Volts_Download_V1.asp
Here's a Datasheet for the Chip:
http://assets.zarlink.com/DS/zarlink_MT8880C_SEP_05.pdf
Thanks...pardon the wordiness
Rafael
Post Edited (flyingfishfinger) : 6/27/2006 2:05:21 AM GMT
Rafael
What development board are you using for the BS-2 application?
Bruce Bates
<!--StartFragment -->
Rafael
I think I got my bits straight. The Chip now listens to me. Turns out it WAS a dumb mistake - I went back and checked what exactly the demo program for the BS1 from the Nuts and Volts Column does at bit level. I found that I had forgotten to set the Register select pin low after my initialization - so the Chip thought all the data I was sending was going to the control registers.
The above code was overly complicated as usual
Thanks for looking anyway
Rafael
I want to use the ESt pin for tone detection. When I attach a LED to the pin, it lights up when there's a tone and my meter shows 5V. When I attach it to the Stamp pin, all it ever sees is a 0. When I attach the Stamp pin to +5V, it shows a 1 like it should. Could the Stamp pin be sinking more current than the Chip can supply? It can't be more than a LED, can it?
Rafael
Steve
Rafael
Rafael
An earphone to the TONE input??· I know that you can use those old in-ear sorts as a really crummy microphone, but...· The tone input should be capacitively (AC) coupled to the "source".
ESt -- is it to confirm a tone generation or a tone reception, or both, depending?
Post Edited (PJ Allen) : 6/29/2006 2:30:04 AM GMT
Rafael
Steve
Rafael
PS: How much current does it take to drive a Stamp pin high? I just realized that the ESt pin can only source -3.0 mA...(but why negative?)
You've got to play the game.
You can't win.
You can't break even, except on a very cold day.
It doesn't get that cold.
~Laws of Thermodynamics~
Post Edited (FlyingFishFinger) : 6/29/2006 9:00:29 PM GMT
Is it O.C.?·
How does it perform if you connect ESt to +5 through a 47K-100K resistor (but not connected to a STAMP pin)?
Rafael
You can't win.
You can't win.
Thanks for the help
Rafael
You can't win.
