Giant BS2 Controlled Arm
Hey Every One,
I recently aquiard a new project for a tradeshow display.· The company makes tool support arms, the arms hold your tool and so you only exert enogh force to move the tool, not hold the weight.· My project is to automate one on these arms so that it can tap holes (or run a tap though a previously tapped hole).· I think I can handle this, but I thought I'd let everyone know, incase you have any ideas.· I ordered some servos to·rotate the top and bottom portions (yes, I·checked the torque, and yes the servos will turn it).· I'll use a solanoid valve to raise and lower the parellel arms.
NerdMaster
For
Life
NerdMaster
For
Life
When dealing with 'real' hardware (ie too big, heavy, or powerful for you to pick-up or stop with your own muscles) the consequences of out-of-control code can injure people (or break equipment). Thus the need for a way to kill the thing before serious injury results. This is critically important in early development, when out-of-control code is most likely.
Just be aware. An out of control BOE-Bot can be picked up and just spin its wheels until you can shut it off. Not so with this robot arm.
NerdMaster
For
Life
If the arm doesn't already have a non-BS2 related emergency shut-off, you might want to mention it to the manufacturer.
NerdMaster
For
Life
But of course, you THINK you're never going to sell one like this. As soon as people see how cool it can be, they may ask for it.
Is it hydraulic? You could adjust hydraulics and when someone hits the kill switch it drops power to the pumps. It shouldn't drop in this case.
If it's servo operated you might look in to the springs you see on the desk lamps (actually, yours looks remarkably similar to my desklap in front of me)!...the springs should offer some resistance to bring the instrument to a neutral position, not all the way down..
If it's a demo, be sure to include all the bells & whistles to impress people!
Steve
NerdMaster
For
Life
