·· The text to speech module uses a TTL level serial input to decode text into the speech.· The SRF04 takes a trigger pulse and returns a pulse corresponding to the distance of an object.· The two items wouldn't work together.· You would need a microcontroller such as the BASIC Stamp to read one (SRF04) and output the data to the other (Emic TTS).·· I hope this helps you out.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support csavage@parallax.com
Any ideas on how to build a counting stamp on lets say 500 pulses/min and have them speeched every hour?
Ie this is a project to transfer electricity consumtion...
Just forgot to mention I have a Siemens PLC for the timing and clock superwiseing!
I have been experimenting with the EMIC system and forum readers know (the male and female voice questions). I used the PING module to determine a distance that the EMIC system then speaks or, in another version, have to robot state... "you're took close.... back away or I will call my master"
Post Edited (Gunnar) : 7/17/2006 5:09:17 PM GMT
