BS2 or SX or Propeller?
Hi Guys!!
I have some experience with microcontrollers but have never touched a BS.
Propeller seems to be the first multi processor chip among BS2/SX/Propeller.
I assumed that while programming on BS2 and SX chips, the program follows
a single thread. I mean its doing only a single task at a given time. (Of course
there is only one processor!)
An autonomous robot may have several inputs coming in from various sensors.
Does the Propeller chip has an advantage of being able to process the inputs
parallely (because of its 32 processors ) ?
I am almost sure that SX should be able to deliver the quickness to an autonomous
robot, even if the programming is single threaded. Does Propeller give any benefit
over and above that? ( Easier to program, better response, simpler circuit )
Thanks for reading,
Ashok
Thanks for reading,
Ashok
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
I will stick to the plan of starting with BS . Which was my earlier plan till i
got confused by Propeller's capacities which exactly matches the power
needed for an·autonomous robot.
I didnt want to start on a project where i run out of program space and
the scratch memory and then end up realizing that the response time
is not sufficient for smooth operation of an autonomous robot.
But still starting with BS seems to be more appropriate as you suggested.
I also hope propeller starter kit becomes less expensive when am finally
at a stage to start on propeller.
Thanks Again,
Ashok.
The school nerd
