PBASIC 2.2x No Disk in Drive Error — Parallax Forums
M BushM Bush Posts: 13
edited 2006-06-25 20:20 in General Discussion
I just installed PBASIC 2.2.5 on my acer laptop running XP Pro SP2.· Whenver I start the program, I get an error message "There is no disk in the drive.· Please insert a disk into Drive E."· Now drive E is the DVD/CD and I have no memory sticks installed (which caused the problem for another person).· I can hit Cancel twice and everything is OK, but is there a way around the error message?
    edited 2006-06-24 17:15
    How did you install PBASIC 2.2.5 ?
    Did you perhaps install it from the DVD/CD or try to load a file that was on a DVD/CD ?
    Try loading a valid .bs2 file from another drive like "C:" , save it as a different name, and then exit PBASIC 2.2.5 ...does the problem still persist the next time you load PBASIC 2.2.5 ?
    Beau Schwabe
    IC Layout Engineer
    edited 2006-06-24 22:25
    Does the problem persist if you restart your computer?
    csavage@parallax.com
  • M BushM Bush Posts: 13
    Thanks to both of you for responding.
    The problem persisted whether I installed from the CD or a file on the desktop. HOWEVER, rebooting the computer seems to have cured it!
    I approciate the help!
