SxSim and the SKIP instruction
chuckj
Gunther,
Thanks for SxSim.· It has saved me lots of time debugging on chip.·
I have found·one problem though - the SKIP instruction works when on an even address (SASM generates $702 instruction), but not on an odd address (SASM generates $602).· Try the following program...
······DEVICE··SX28,OSC4MHZ,TURBO
···· ·IRC_CAL··IRC_SLOW
···· ·FREQ··50_000_000
····· RESET··bgn
bgn:
····· clr··· ·w
···· ·skip
···· ·mov· ·w,#1······ ;· This instruction is executed - but shouldn't be!
···· ·clr···· w
···· ·skip
···· ·mov·· w,#1······ ;· This instruction is correctly skipped.
···· ·jmp··· bgn
If you load this into SxSim and step through it, you will find that the first 'mov' is executed, although it should not be...
chuck
····· RESET··bgn
bgn:
····· clr··· ·w
···· ·skip
···· ·clr···· w
···· ·skip
···· ·jmp··· bgn
chuck
When the SKIP is at an odd address the display shows the next instruction as "SNB PC.0", but PC.0 is 1 at an odd address, so it won't skip ???
Might have something to do with how the hardware pipeline handle the PC register ???
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"I reject my reality, and substitute yours." NOT Mythbusters
oops - you really found a bug!
This made me aware that the SX does not have a SKIP specific instruction. It is the assembler that "understands" the SKIP and converts it into SB 2.0 or SNB 2.0 (SB PC.0 or SNB PC.0) depending if the SKIP is located on an odd or even program address. The problem with SXSim was that it only handled the $702 code correctly. This is fixed in the most recent version 2.08.05 that I'm going to attach to the "sticky" SXSim thread.
Thank you for helping to improve SXSim.
Greetings from Germany,
G
