NOOO!! shortcut servo controller and basic stamp 2!
I totaly messed up today!
I`m using 2 servos to control a boat, by a servo controller and a BS2
When I was soldering the second servo, somehow a lose cable touched a voltage regulator and the connection green flashing·LED on the servo controller·died. The connection between the BS2 and servo controller somehow·disapperad.
I used a multimeter and discovered that the servo controller no longer got 5volt from the BS2, only 1.7 volt. I have probably shortcut the BS2 so that it´s broken. The servo controller seems to work·if I use·external 5volt.
Also, when I tried to turn a servo through pushing a button, to the BS2, the red LED lights on the servo controller up alot but nothing at the servos happens.
Any ides!?
Any ides!?
csavage@parallax.com
If not, you may need to replace the BS2.
Wait -- what the hell are you doing soldering on a servo with the power on the BOE anyway?· This stuff should be done with the power off.
The power supply from the BS2 seems to be gone, what was 5 volts is now only 1,7 volts, so I don`t think there is a I/O problem at first. But I could try to move the pin!
I also used another power source to the servos.
