useing COUNT on multi lines
·· What would be the best way to go about·COUNTing·5 RPM lines?·· I use the·MCP23016 I2C I/O expander right now.· I used the INT·on the MCP with a pulldown going to stamp Pin7.· This works and only uses 1 pin but there has to be a better way.
This is some of the test code
I know I can walk through each pin with the < and some vars for 1·small loop but for now I am just looking for a diff/better way to do this.· Starting to think the MCP230xx is not the best way.
RPMCheck: '*************************************************************************** I2COUT SDA, %01000000, GP0, [noparse][[/noparse]%00000000,%10000000] I2COUT SDA, %01000000, IODIR1, [noparse][[/noparse]%10000000] COUNT 7, 910, RPM1 SEROUT LCDO, 396,[noparse][[/noparse]254,71,17,3,"FAN1"] SEROUT LCDO, 396,[noparse][[/noparse]254,71,17,4,DEC2 RPM1] '*************************************************************************** I2COUT SDA, %01000000, GP0, [noparse][[/noparse]%00000000,%01000000] I2COUT SDA, %01000000, IODIR1, [noparse][[/noparse]%01000000] COUNT 7, 910, RPM2 SEROUT LCDO, 396,[noparse][[/noparse]254,71,17,3,"FAN2"] SEROUT LCDO, 396,[noparse][[/noparse]254,71,17,4,DEC2 RPM2] '*************************************************************************** return
