Good Day Help french for programming SC28AC/DP 9812
I am to be possession of 100 integrated SX28AC/DP 9812
Programming error with SX Tech rev F and soft Sxkey v3.1 r2, Help me, thank you
Cheap 4-digit LED display with driver IC·www.hc4led.com
"I reject my reality, and substitute yours." NOT Mythbusters
The 9812 date code chips need to be programmed with the older version of the software (I don't remember which
version of the software you will need). The·fuse register is different. Also, there·is no debugger built in to the hardware...·· ...so you can't in circuit debug these chips (9812's are very old chips).
I have about 25 of these chips as well.
-Dan
