Downgrading from SX52 to SX48 and PORTA
With the downgrading from SX52 to SX48, I am obviously losing the high nibble of port A.
I have code similar to the following, with port a set to outputs:
MOV $05,#$FF
If I were to test pins 4-7 using SB or SNB, would it be accurate?
Mark
MOV $05,#$FF
Mark
Nate
Yes, If the pins are set to output, they will read-back the value they are set.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"I reject my reality, and substitute yours." NOT Mythbusters
Life is one giant teacup ride.
