Doesn't recognize!!
I've just assembled the BS2 OEM version but the computer cannot recognize it. When I click 'run' it says YES to loopback and echo, however seconds later reports that it cannot be found. I substantiated every component if it was installed correctly, but found no errors.
Vladimir
Vladimir
Did you get all of the pins of the microcontroller placed in the socket properly?· Look for pins which may have curled under.
Inspect for solder bridges.
Done much soldering before?
Any of the components getting HOT?
Ever had a STAMP work·with your computer before?
I've inspected the pins if were soldered correctly, no bridges, and yea, I have done quite of times of soldering.
the regulator gets a bit worm when I start the transfer
and no, I've never had any other BS2 to work with computer. I've tried to do so on my other computer but ended up with adverse results.
Should I call parallax?
Vladimir
What kind of serial cable are you using between the computer and the BS-2 OEM board - is it a straight-through cable?
Do you have the BS-2 Chip oriented properly, without any pins hanging off of the socket (presuming it's socketed)?
Are you using the parts suggested by Parallax without any substitutions?
Is this a desktop or a laptop computer, and which operating system are you using?
Which version of the PBASIC Editor/Complier are you using?
Bruce Bates
<!--StartFragment -->
I've inspected the BS2 again, however still do not see any pins sticking, as well as the chips are inserted properly.
I used only parts that were included within the provided kit
The windows I have is Win XP Home desktop
The PBASIC compiler that I use is 2.2.5
If you require, I may provide you with a snapshot of the BS2 and how I assembled it. This may help you to identify the error that I might've committed.
Vladimir
· Mine worked first time.· Prior to that, I'd worked with a HomeWork Board, so I had·everything I.D.E.-wise·covered going in.
I had the same experience with the first BS2 OEM I assembled--put it together but the PBasic Editor could not communicate with the BS2. It turned out that I'd done everything correctly but the USB-to-Serial converter I was using did not support all the RS-232 signals so as far as the PBasic Editor was concerned, my BS2 lacked power and/or communications capability. Once I bought a compatible USB-to-Serial converter, my BS2 OEM checked-out as OK.
I wouldn't connect that if I were you...
Vladimir
· "When in doubt, ohm it out."
Vladimir
If it was mine, I'd troubleshoot:
For #s 2 & 3, you'll need an oscilloscope.
Vladimir
Vladimir
Y/N?
Vladimir
