Whisker sensors adjustment
When roaming with whiskers my Boe-Bot would somtimes backup at an angle pressing the whisker forward and eventually pulling the whisker off. The solution I found for this was to place the whiskers in between the contact pins instead of in front of them, it took a few minutes to center them between the pins leaving a smaller gap but it worked perfectly and make them more sensitive and secure. Check out this diagram for a closer look.
I like you diagram!
I had the same problem and also came up with the same solution.
Another problem I had was that the whiskers were too high up to detect low-laying obstacles.
As a primitive but easy solution, I replaced the tall stand-off's with short ones.
