Push Button
To anyone that can help,
I want to have my code run only when a button on the starter kit breadboard is pressed and then stop when it is pressed again. I was wondering what code and setup would be needed to complete this idea. Thank you for any help.
Sincerely,
Sincerely,
regards peter
I appreciate all of the help. I was hoping someone could explain the wiring on the breadboard to make a button work with the posted program. Thanks.
Sincerely,
Connect a normally open button between GND and javelin I/O pin 0.
regards peter
Connection VDD is the +5V. The demoboard
is described in the manual.
regards peter
Sincerely,
You will get better responses·if you attached your entire program and a detailed
description of your hardware setup.
regards peter
while (!isButtonPressed(1))
by
while (!isButtonPressed(CPU.pin1))
Change isButtonPressed by
··· private static boolean isButtonPressed( int pinNumber ) {
······· return !CPU.readPin(pinNumber); //return true if pin low (eg. button pressed)
regards peter
Sincerely,
that is the pin used in the Uart declaration.
Make sure the javelin GND is connected to the servo board GND.
regards peter
Sincerely,
Jon
