Calculating Variometry
It's been awhile since I've touched my project, but I'm getting back into it. I'm building a flight instrument for hang gliding. I have figured out how to calculate altitude using a pressure sensor. Now I'm trying to calculate my variometry (rate of climb or decent). What I wanted to do was store my last altitude, then subtract it from my present altitude to get the change. Atlitude is recorded every one second and altitude is given in feet. This calculation would give the result in feet per second. The final result needs to be feet per minute and will be displayed on a LCD. This would be easy except that values can be negative. So the question is how do I need to deal with this math in the Stamp's integer math world without it getting confused. If someone knows a better way to calculate my variometry, I'm open to new ideas. Thank you in advance for any help on the matter.
David
David
if current > previous then ascending
change = previous - current
dispSign = "-"
goto continue
ascending:
change = current - previous
dispSign = "+"
continue:
result = change * 60
serout pin,baud,[noparse][[/noparse]dispSign,DEC result]
The main thing you have to watch out for with the signed math with integers is division. Addition, subtraction, and multiplication all work fine with the twos complement numbers, and you can display the negative numbers using the SDEC modifier.
So
feetChange = feetNow - feetPast
DEBUG SDEC feetChange * 60
feetPast = feetNow
The issue with twos compliment negative numbers comes with division, including / and //, and */ and ** operators. There are special tricks for division, or if the display needs a decimal point, but I doubt if that is a issue with data in feet.
Tracy Allen
www.emesystems.com
Thanks for the suggestion. I might use that if I have to.
To Tracy,
If I did a comparison, would the stamp know that a negative number was lower.
Example, I want audio to turn on if my rate is over 100 feet per min. If the rate is -200 feet per min, would it see it as 100>-200 or would it see it the other way around? I'm trying to make sure I keep any unusual behavior down. Thanks again!
David
Steve
If you want both ascent and descent with the same threshold, use absolute value.
IF ABS rate > 100 THEN ...
One easy way handle separate thresholds cleanly is with a positive offset:
SELECT rate + 10000 ' <- offset makes it positive.
CASE < 9900
' descending
CASE > 10100
' ascending
END SELECT
The number 10000 is arbitrary. But if your descent is faster than -10000 ft/m, you're in serious trouble!
Tracy Allen
www.emesystems.com
Yeah, that would work fine. Oh, and you're very right on the 10,000 ft/min thing. I've felt 2,000 and that's scary enough!
The period averaging would be a great thing to add. How should I go about storing and averaging values over a selectable period of time? A good range would be 0 - 20 seconds, but can be made shorter if possible.
Thanks to everyone for the great help so far. I hope this becomes useful for someone else too.
David
Tracy Allen
www.emesystems.com
