Having problems powering BS2
Hi,· I have a 9v battery that I've been connecting to the VIN(red or +) and VSS(black or -).· When I run the BS2 editor it can see the stamp but it cannot recognize it.· I mean it 'Echo' and 'Loopback' = Yes but the Version is not indicated, and the battery starts to get very warm.
Obviously, I'm new at this.· What am I doing wrong?
Take a look in the PBASIC Stamp Manual to be sure you have the orientation of the Stamp correctly mounted in its socket. Also make sure you've not shifted the Stamp in the socket such that some of the pins are socketed and others are not.
Bruce Bates
<!--StartFragment -->
csavage@parallax.com
I wouldn't connect that if I were you...
Just to be "fair" it could well be "that one" (the one getting hot) or a component downstream of the one getting hot. "Shorts" can certainly run upstream in attempt to blow the blue smoke out of the weakest or lowest rated component, somewhat regardless of which one feels hot.
I've seen a short in a 3 phase 25 KVA transformer 480V x 208/120V transformer blow the line tranformer off the outdoor power pole, without trupping any of the three breakers in between! Needless to say the power company was somewhat embarrrased.
Bruce Bates
Do you have a VOM/DVM/DMM that you can use to measure the voltage present on the wires coming from the battery clip? If so, do you read close to 9V or something much less (6 to 7V)? If you read 8V or more, does that voltage decrease when you connect the battery clip to the load (the BS2 board)? It should drop a little under load but not down to 6V or 7V unless, a) the battery is weak, or b) you've got a short somewhere.
How about this? Does your BS2 board have a breadboard on it and are you connecting Vdd to Vss (Ground) with a resistor of say, 47Ohms, or less? A small value resistor connected across the power supply rails will draw current, pull your supply voltage down, and create heat.
