DTMF X-10 PHONELINE project
hey everyone - so i want to do the following:
have my Bs2SX hooked up to the phoneline "listening" for it to ring.· when the phone rings it picks up and beeps a couple of times prompting me to enter a password. i type in my 4 digit code.· then it beeps me the status of my window airconditioner (if its on or not) i can then hit a number on the phone turning the A/C on via X-10 with stamp.
this would be AWESOME but....can it be done?
thanks
steve
thanks
steve
My question to you is, have you worked much with stamps? If not, I'll suggest the "What's a Microcontroller" text from Parallax. It's free to download and has lots of neat tutorials to help you learn the stamp.
As far as you project idea goes:
You could have an old external modem connect to the stamp for comms.
Have a couple of I/O's on the stamp monitoring the Airconditioner. Now the question is, what on the air conditioner are you going to monitor? You could put a couple of temperature sensors in there...one for ambient air and one right in the A/C's flow.
OR, you could put a small microswitch with a foil "sail"....when the air is flowing, it blows against the "sail" and switches the microswitch (we used to use this all the time in our radars with minimal failures).
Steve
its a window unit...a simple plug into the wall outlet style. all it would do is simply turn the thing on via X-10 because the dials would be set up already - it would just need power.
to interface the stamp to phone that my only obstacle. i saw in the owners manual that circuit to hook the stamp to a phoneline with a transformer and everything. i thought i could just do that? i need a modem?
steve
The chief advantage is that that the modem has already been approved to plug into the phone system, can auto answer by itself and is easy to interface with the stamp serially.
Cheers
