Problem debugging on my laptop...
I have a program that reads the temperature from a DS1624 and I'm trying to debug it.
This seem to work fine on my Desktop, I just hit debug and I can walk through the whole program...
However doing the same thing on my laptop (same software and SX Key), the debug window closes unexpectedly...
It seem to run for 2 to 3 minutes before closing the debug window...
Anyone seen this before ???
Would it help to use a USB to serial adapter in stead of the serial cable ???
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
Experience level:
/Bamse
Some notebooks do funny things with the serial port (like shut them down) to conserve power.
Does it work if you have the notebook plugged into the charger ?
You could try a USB adapter, but it's kinda expensive for a shot-in-the-dark fix.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"I reject your reality, and substitute my own." Mythbusters
I plugged in the charger and re-programmed the SX.
The actual erase/programming part seem to go well.
It's just the debugging...
I'm going to see if I can find any switch to disable power management for the serial port...
And unless I'm 100% sure I can get the whole thing working with a USB to serial, I'm not buying the adapter...
Thanks Bean...
Experience level:
/Bamse
In the Device Manager, Ports (COM & LPT), Communications Port (COM1).
Double click and select the Port Settings, click the Advanced... button.
Set the Receive buffer and Transmit buffer to 1 under the FIFO buffers.
Click OK and OK again to exit the settings...
Here is the trick, DISABLE and then ENABLE the device...
Or reboot probably works as well...
Anyway, I walked through my whole program and was able to debug in the same way as on my desktop...
Experience level:
/Bamse
Changing the FIFO settings is the standard approach to fixing these sorts of problems. It doesn't always work, but it does work for a large number of cases. I was going to post the info to you, but didn't get on the forum until today. Just curious where you found out to try the FIFO adjuesment.
Thanks, PeterM
·· Rather than turning the FIFO buffers down, we usually recommend disabling them by unchecking the box labeled, "Use FIFO Buffers".· On some systems turning them down does not eliminate the symptoms caused by them being on.
csavage@parallax.com
Actually, turning the FIFO buffers off caused a "Transmission Stall" error during the programming cycle...
However turning them down to 1 seem to work for me...
Anyway, it works now and I'm converting my BS2 programs into SX/B...
Experience level:
/Bamse
