BS1 Serial interface
The 9 pin serial interface used to program the BS1 that takes care of the RS232 to 5v logic, right. So this could be used for and OEM BS2 and not have to worry about the RS232 interface, just add a 3 pin header directly to the BS2 pins.
If you're speaking about the following serial to parallel adapter, it is strictly for use with the BS-1 as far as I'm aware, and would have no practical use on a BS-2.
http://www.parallax.com/detail.asp?product_id=27111
Bruce Bates
<!--StartFragment -->
·· That adapter does not bring out the DTR/ATN line which is essential to being able to program the BS2.
csavage@parallax.com
·· There are already schematics posted for how to connect a USB2SER to a BS2OEM without the RS-232 components.· Please see the following link for more information.
http://forums.parallax.com/showthread.php?p=567989
