stepper motor controller
Hi.
I have a 6 wires stepper motor that needs to be converted to·4 wires. I don't know how ?
can somebody give me a hand.
thanks.
thanks.
toni, your 6 wire stepper motor probably has two common wires connected at the center of each pair of two coils. You can determine which two wires are the center tapped wire by measuring the resistance. End on end between two coils, the resistance should be aproximately double the resistance of that which is from coil to its center tapped wire (the common wire) since there are two coils in series with each other.
I found a better picture, here you go.
Hope that helps.
Post Edited (ktekx) : 6/13/2006 9:25:56 AM GMT
type : 4H4018S0623 1.8 DEG, 15 volts, 0.4 A
And it has 6 wires 2 of them are brown and the four remaining are white, blue, red, yellow.
maybe the 2 connected wires are the 2 brown ones ?
Should i neglect these when i connect it as four wires. ?
many thanks.
csavage@parallax.com
I can not to find the ground.plz help me!!!
many thanks.
Generally speaking the two common colored wires are the "ground" wires. This can be proven by use of an ohmmeter. If you need the troubleshooting sequence, just ask.
Bruce Bates
<!--StartFragment -->
