12 volt 6 amp power supply
I constructed this circuit on a PCB for a benchtop power supply (also an electric motor supply for my bidirectional PWM fan driver). Do you think its a good design?
Well well, I'm seeing things, three of them.
-Stanley Blystone
-Stanley Blystone
Apparently they begin to destructively oscillate.· There are other designs that use a power transistor following the regulation that are quite good and actually less components.· Take a look as the suggested circuits on the 78XX series PDFs from the manufacturers.
With all good power supplies, you should start out with fusing and spike rejection from the AC line, then a step-down transformer, then good ripple rejection, and then your regulation.·
Post Edited (Kramer) : 6/10/2006 8:37:08 AM GMT
78xx regulators in parallel don't/won't share the current as you expect; one will end up with (much) more than the yeoman's duty, a lot like "current hogging" with LEDs in parallel.
But with luck,it will sometimes work out,as I have found.One circuit I
have in extreme conditions does fine with 2 paralled.
Here's a statement that sums it up:
Unfortunately, you can't rely on this circuit to work every time. If the regulators are very well matched (same batch) it might work. If they have significantly different output voltages, one will volunteer more current than the other and you will find it shuts down well before the circuit gives the X2 maximum current. It is a perennial problem with regulated supplies, if you want to parallel them, you need some sort of active current sharing circuitry as well.
Thanks, Parallax!
You could have six independent 1 amp outputs instead or even more. It only becomes a problem when you want to drive over the 1 amp. While they claim to make 3 amp 78XXs, it seems that they are near impossible to locate and it is just easier to use a 3055 that is controlled by the 78xx.
Thanks [noparse]:)[/noparse]
-Stanley Blystone
Here is a link to a 5 amp regulator LM3138 / LM338 that can do what you want.
cache.national.com/ds/LM/LM138.pdf
Towards the bottom are examples of circuits, that can handle higher amperage..
Bob N9LVU
-Stanley Blystone
You've got diode 2 in the wrong place!!!!!
Here is the image as an attachment.
Bob N9LVU
Post Edited (Robert Kubichek) : 6/11/2006 1:45:42 AM GMT
-Stanley Blystone
Ok, you forgot one critical safety item " fuse the ac side of the circuit so if it overloads it kills the ac power....
And I don't know if I would combine the circuit dc ground to the case/ac ground, but in that, I could be wrong...
Bob N9LVU
-Stanley Blystone
http://forums.parallax.com/forums/default.aspx?f=15&m=129331
...I realize that building your own is a Good Thing but I had an ATX PSU laying around taking up space so I put it to work. [noparse]:)[/noparse]
I wouldn't connect that if I were you...
Thank you all for your help [noparse]:)[/noparse]
-Stanley Blystone
My experience with switch mode PSUs (which is what PCs use) is that·one has to draw·some minimum current on one circuit for the others to work. Is this the case with PC power supplies? Which circuit needs the current?
Please, any PC or switch mode gurus, your comments
Also, I would place independent quick blow fuses on each voltage, I have·shorted a PC supply into a spectacular display of·pyrotechnics. Maybe they're better these days but it's not an experience for us timid souls.
I've avoided using PC supplies for general use since that incident. In fact, I've avoided switch mode units generally. It would be useful to have +5V -5V +12V -12V and +3.2V as a single unit right on my bench. I'll put a dummy load, say 0.2 Ohm 10 watt across the 5 Volt.
Obviously, my ancient variable supply and the half dozen LM317 and 7805, 7809 PSUs will give much smoother power but my bench is getting very crowded.
John
