Extra program space?????
Q1: I wonder if I can use EEPROM chips to expand program space....?
Q2: How can I use an SD card with a BASIC Stamp?????
Any ideas???
Thanks in advance.......
Any ideas???
[b]Mukarram[sup]Emc[sub]2[/sub][/sup]Ahmad[/b]
"Q2" an SD card could only be used to store data, but not as program space.
http://www.sparkfun.com/commerce/product_info.php?products_id=204
you'll also need the actual socket
http://www.sparkfun.com/commerce/product_info.php?products_id=136
you'll need a firn understanding of how the FAT filesystem works, too.
Also, there may be a few clues if you read the Spin code(for the new Propeller chip) attached to this thread:
http://forums.parallax.com/forums/default.aspx?f=25&m=126973
(Note that this only deals with READING from the card, yet)
In fact, the best way to use such card for writing is to make certain that it is completely empty(format it on a PC), then create a large file on it. That will make certain the file is continuous(saves you a lot of work traversing the FAT) so that you can just address the card directly.
Of course, if you don't need to read it on a PC, only on the BS2, you won't need ot worry about using the FAT and can make up your own storage scheme.
Don't visit my new website...
